 Ford F150 2004, procédure de reprogrammation pour le keyless entry pad sur la porte
Nombre de messages : 393
MessageSujet: Ford F150 2004, procédure de reprogrammation pour le keyless entry pad sur la porte   Mar 7 Avr - 18:55
salut ford f150 2004 quelque a la procédure pour reprogrammer les barrure de porte digital et ou je peut trouver le code merci
MessageSujet: Re: Ford F150 2004, procédure de reprogrammation pour le keyless entry pad sur la porte   Mar 7 Avr - 20:40
•Description and Operation
KEYLESS ENTRY KEYPAD
The keyless entry keypad, located in the exterior handle of the driver door, provides a method for the customer to access their vehicle without a key or remote transmitter. The keyless entry keypad feature:
•locks all doors and inhibits the door lock control switch unlock capability after 20 seconds (if the inhibit feature is enabled).
•unlocks only the driver door.
•unlocks all doors.
•programs/erases customer key code.
•enables/disables autolocking.
The keyless entry keypad feature operates independently of key position status, vehicle speed, or transmission position. When a keypad button is pressed, the keypad buttons illuminate to provide better visibility. If LOCK ALL DOORS is entered or 5 seconds have elapsed since the last button press, the illumination is turned off.
Each vehicle equipped with a keyless entry keypad is programmed with a 5-digit entry code. This code is provided to the customer through a wallet card in the owner literature package. In addition, this code is available through a diagnostic tool and is also printed on the vehicle security module label. When entering codes each digit must be entered within 5 seconds of the previous button press.
Anti-Scan Feature
To provide added security, the keyless entry keypad is disabled for one minute after 35 button presses without a valid entry code being entered. The keypad flashes during this one-minute mode with all functionality disabled except for 7/8 and 9/0 still being allowed to lock the vehicle.
Anti-Scan will be turned off after one minute of keypad inactivity.
Unlocking the Doors with the Keyless Entry Keypad System
To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within 5 seconds of the prior digit). The interior lamps will illuminate.
To unlock all doors, enter either the factory set code or the personal code (driver door unlocks) and press the 3/4 control within 5 seconds .
Locking the Doors with the Keyless Entry Keypad System
It is not necessary to enter the factory set or personal code prior to locking all doors. To lock all doors, press the 7/8 and 9/0 controls at the same time
KEYLESS ENTRY KEYPAD CODE PROGRAMMING
1.Enter the permanent factory keyless entry keypad code.
2.Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds after activation will erase the stored customer code. The door locks will lock, then unlock, confirming the code is erased. The existing code will not need to be erased to program new a code.
3.Within five seconds , enter the new five-digit keyless entry keypad code. The door locks will lock and unlock to confirm the new code is programmed
MessageSujet: Re: Ford F150 2004, procédure de reprogrammation pour le keyless entry pad sur la porte   Mar 7 Avr - 20:42
les 5 chiffres originaux devrait etre dans le coffre a gant écrit sur une carte
Nombre de messages : 1047
MessageSujet: Re: Ford F150 2004, procédure de reprogrammation pour le keyless entry pad sur la porte   Mar 7 Avr - 20:46
Dans keyless entry module dans data dans ton scan autel te suposser le voir
Ou sinon le coller sur le module
MessageSujet: Re: Ford F150 2004, procédure de reprogrammation pour le keyless entry pad sur la porte   Mar 7 Avr - 22:30
merci franck2216 le client revient vendredi pour s est tire d été je te revient sur sa pour te donner des nouvelle
merci aussi PassthruJ2534
tilaff
Nombre de messages : 415
MessageSujet: Re: Ford F150 2004, procédure de reprogrammation pour le keyless entry pad sur la porte   Mer 8 Avr - 9:50
coffre a gant sur une carde sur le module keyless et dedans avec le scan dans securiter
MessageSujet: Re: Ford F150 2004, procédure de reprogrammation pour le keyless entry pad sur la porte   Dim 18 Oct - 19:19
le client est venu au garage et il ma demander la procedure voulais le faire lui meme je les imprimer et lui donner pas revue le client il vas surement venir faire son changement de peun vas lui demander
