2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar Tournesol Sam 2 Mar - 16:03
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar frank2216 Sam 16 Fév - 22:29
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar Jackson1986 Mer 12 Déc - 4:07
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar tilou32 Dim 2 Déc - 19:28
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar tilou32 Dim 2 Déc - 19:27
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar frank2216 Ven 11 Mai - 9:24
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar Yvon Mer 18 Avr - 21:52
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar frank2216 Mer 18 Avr - 21:04
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar frank2216 Mer 18 Avr - 21:00
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar Yvon Sam 3 Mar - 21:28
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar frank2216 Sam 3 Mar - 21:10
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar Yvon Sam 6 Jan - 10:47
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar Yvon Mar 26 Déc - 8:25
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar Yvon Mar 26 Déc - 8:12
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar Yvon Sam 9 Déc - 20:41
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar Yvon Mar 21 Nov - 21:20
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar Yvon Lun 23 Oct - 19:57
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar PassthruJ2534 Lun 23 Oct - 18:43
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar frank2216 Jeu 21 Sep - 20:46
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Emptypar Yvon Mer 16 Aoû - 23:31
Nombre de messages : 2343
MessageSujet: 2006 chrysler 300 3.5l trouble abs left rear tone ring perf.   2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. EmptyMer 25 Mai - 21:09
je partage ce cas de façon a vous faire sauver du temps lors d'une inspection avec un cas similaire
((((le tone ring est sur le cardan))))))))))
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Image_10
plainte du client abs allume intermittent
vérification juste du code(scan) la semaine passé le trouble se passe dans la roue arrière gauche
visuel et wigle test du filage je vois rien tout semble ok
revenu aujourd'hui pour une inspection plus approfondi du trouble
je vous donne un in enlever la roue puis le boulon 1po1/4 du cardan et si vous poussé dessus le bout du cardan pour le faire sortir du roulement on peu voir le tone ring en place par derrière le hub et confirmer le problème qui manque des aimants
image du cardan et le tone ring endommagé demain @+
MessageSujet: Re: 2006 chrysler 300 3.5l trouble abs left rear tone ring perf.   2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. EmptyMer 25 Mai - 23:13
Thumbsup super bon partage Frank. cheers
Je n'aurais pas pensé que les polaritées pouvaient se dégrader et en manquer des bouts. 2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. 871723
MessageSujet: Re: 2006 chrysler 300 3.5l trouble abs left rear tone ring perf.   2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. EmptyJeu 26 Mai - 6:16
Ce tone ring est extrèmenent fragile. Un coup de marteau sur le disque peut le briser. On démonte beaucoup de ces cardans et juste au démontage, le tone ring casse... Je dirais qu'un cardans sur deux se brise lors du démontage.
MessageSujet: Re: 2006 chrysler 300 3.5l trouble abs left rear tone ring perf.   2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. EmptyJeu 26 Mai - 6:45
Oufff ça va être à y penser quand tu tapoches un rotor. Pas d'abs allumée avant et trouble après. 2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. 871723
Le fameux outil pour pryer les rotors hors de leurs places doit être prescrit dans le démontage.What a Face
Merci Vincent pour cet ajout fort utile. thumds up
MessageSujet: Re: 2006 chrysler 300 3.5l trouble abs left rear tone ring perf.   2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. EmptyMar 31 Mai - 13:00
comme promis vaut mieux tard que jamais smyle
image du soit disant cardan avec le tone ring deffect.
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Sam_1317
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Sam_1316
2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. Sam_1318
MessageSujet: Re: 2006 chrysler 300 3.5l trouble abs left rear tone ring perf.   2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. EmptyMar 31 Mai - 13:01
affraid affraid affraid
Magané ! Queser qui c'est passé pour qui devienne comme ça?
MessageSujet: Re: 2006 chrysler 300 3.5l trouble abs left rear tone ring perf.   2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. EmptyMar 31 Mai - 21:35
Pres de 800 000km affraid
MessageSujet: Re: 2006 chrysler 300 3.5l trouble abs left rear tone ring perf.   2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. EmptyVen 3 Juin - 20:32
Est-ce que le tone ring neuf se vend à part du cardan?
MessageSujet: Re: 2006 chrysler 300 3.5l trouble abs left rear tone ring perf.   2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. EmptySam 4 Juin - 16:18
oui  Arrow ebay
MessageSujet: Re: 2006 chrysler 300 3.5l trouble abs left rear tone ring perf.   2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. EmptyJeu 10 Mai - 21:18
J'ai eu le même trouble sur un 300. J'ai fait à gauche il y a quelques mois. Prise 2 aujourd'hui pour le côté droit.
Vaut mieux l'expliquer au client et l'avertir que l'autre viendra à faire défaut. Sinon ils voient encore la lumière allumée et les mots qui viennent ensuite sont "c'est encore allumé, cest le même trouble...c'est garanti..." 2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. 871723
MessageSujet: Re: 2006 chrysler 300 3.5l trouble abs left rear tone ring perf.   2006 chrysler 300 3.5l trouble abs  left rear tone ring perf. EmptyVen 11 Mai - 9:24
Oui sont facile sur le sa pas été bien réparé la 1er fois
